1964 Impala SS - Intake Manifold Torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2010, 01:32 PM
64Joker's Avatar
64Joker
I have a small amount of oil coming out of a few of the the intake manifold bolts. What is the correct torque required to tighten the bolts? Any other suggestions?
Car: 1964 Impala SS
Engine: 327 cu.
Transmission: Automatic
Intake Manifold: Edelbrock (not sure about the specs). (See Pic).
Thanks in advance...
Old 07-06-2010, 01:44 PM
poncho62's Avatar
Wiki Edits: 5
Not sure of the exact torque, probably 25# or so......They also should be torqued in 2 or 3 steps in a specific pattern, just like head bolts.....from the centre out to the ends......
If you are leaking oil now, I would think that the gaskets need to be replaced.....you might get lucky just tightening them....maybe not
Ontario Rodders
Old 07-06-2010, 01:47 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Torque should be 25# for aluminum 30# for cast and in steps like poncho said.
Cole
Old 07-06-2010, 01:59 PM
Sinister's Avatar
You need sealant on the intake manifold bolt threads. I usually use oil resistant RTV.
Old 07-06-2010, 02:07 PM
Hippie's Avatar
Last journal entry: HEI comparison.
I'll second that and that the bolts need sealant.
Old 07-06-2010, 03:13 PM
sqzbox's Avatar
My pipes are my music
Ditto on the sealant. I had that problem even after final assembly with new gaskets on my edelbrock. Oil would pool in the center bolt locations. I removed them and ran a bead of permatex red under the washers on the intake bolts and have had no more problems.
Right cam for a 383? atomicrockerdude Engine 23 11-02-2009 12:13 AM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
1964 Impala SS - Headliner Question 64Joker Interior 8 07-11-2009 04:20 AM
1964 Impala SS - Shifter Linkage Bushings 64Joker General Rodding Tech 4 12-12-2007 09:07 PM
1964 Impala SS Dash 64Joker Interior 3 06-21-2007 11:30 AM
