Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1964 Impala SS Interior Bucket Seats
Old 03-25-2013, 07:35 PM
gratefuldad gratefuldad is offline
I can answer definitively as I just finished restoring my front buckets. I used PUI interiors, black vinyl. The top portion (back support) is identical on both sides. The bottom (***) portion has a slight difference between them. If; however, you wish to use them interchangeably it is possible. I know this because I found it out the hard way. Not knowing there was a difference, I was well into restoring the first seat before realizing this. I was already too far down the road and left it as is. I had already cut a hole to fit the hinge that the back seat attaches to. Both seats turned out nearly perfect as it was, but if you are doing this for a trailer queen and that sort of thing matters, then there are slight differences between the two bottom covers.
