1964 Impala SS - Stop Lamp Switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2010, 11:28 PM
64Joker's Avatar
64Joker
I'm attempting to identify 2 wires off of the neutral safety switch harness that are located under the dash (opposite end of where the neutral safety harness ends at the shifter). I think they are supposed to connect to the "stop lamp sw" connector (2 wires - black/orange & black/white with "T" configuration connectors). Can someone define a "stop lamp switch"? I don't see were this connection is made!?? Thanks in advance!
Old 07-13-2010, 12:35 AM
64Joker,
Look on the right side of the brake pedal you should see the switch from there. It is attached to a bracket and the movable end is facing down toward the brake pedal. On the back side there are two spade connections. Try looking there for your missing wire connectors
Scholman(retired)
Old 07-13-2010, 07:24 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Stop Lamp switch is a '11' type of connector.
I believe an orange wire going in and a white wire to the turn switch
The black and white wires with tracers are commonly dome or courtesy lamps and if the wires do not have a connector on each wire, the 2 wire connector will be a T
Old 07-13-2010, 06:43 PM
64Joker's Avatar
64Joker
Follow-up
You are correct! I located the "T" female connector under the dash (it was hiding! :-) and was able to get 2 of the 3 lights working at the console area. My mistake on the "stop lamp switch" (wiring diagram?!), it was not part of the configuration, sorry!
The final light connector NOT working is the transmission (park, drive, neutral, reverse, etc). There are 2 wires (black and grey) leading to a plastic bulb connector (not sure what bulb #). One is obviously a ground (blk) and the grey wire leads back to the dash with a small metal connector, which I can not located on the wiring diagram???
Is it possible the grey wire goes to the "Lamp" fuse box connector?
Any ideas?? Thanks again....
Old 07-15-2010, 12:03 PM
64Joker's Avatar
64Joker
Final
I was able to trace the problem back under the dash, there was a broken wire that leads to the "lamp" fuse box, fixed it, it works! Continuity test passed! Thanks for your help!
1964 Impala SS - Windshield / Back Glass Trim 64Joker Body - Exterior 1 10-27-2009 08:36 PM
93 TBI with Impala ss lt1 cam? Is it worth it? cusz28 Engine 11 10-16-2009 02:59 PM
1964 Impala SS - Headliner Question 64Joker Interior 8 07-11-2009 05:20 AM
1962 Impala SS on the tree/AC 235 engine lolli780 Hot Rod Art 1 11-13-2008 10:33 PM
Tail Light Malfunction beau8788 Electrical 5 10-11-2006 07:38 AM
