1964 nova cover plate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2006, 04:18 PM
mkn mkn is offline
I have a 1964 nova with a stock rear end it is a 10 bolt but it has a cover that looks like a 12 bolt it has the v on it .is that common?
I just wount to say thanks to all that have helped me out with some of the questions i have had.
m.k.n.
Old 10-19-2006, 05:25 PM
Will I ever get it done?
Last journal entry: Driver's Door
The "V" in certain GM cover plates was an aid to lubing the outer axle bearings. The ring gear will throw lube up on the back cover. The "V" will direct the lube outward to the two holes in the housing. From there, it will go into the tubes and hopefully lube the bearings.
1968 Nova SS is about to end its Life Seagroves Hotrodders' Lounge 50 10-20-2009 06:04 PM
rear end 1964 nova mkn Transmission - Rearend 2 08-16-2006 06:59 AM
63 Nova Front & Rear Seats Mustangsaly Interior 3 10-13-2005 09:44 AM
Favorite magazine cover of all time willys36@aol.com Hotrodders' Lounge 13 09-23-2005 07:08 PM
63 nova discs jtdchevy Suspension - Brakes - Steering 6 05-11-2004 11:35 AM
