Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1964 nova cover plate?
Old 10-19-2006, 05:25 PM
redsdad redsdad is offline
Will I ever get it done?
Last journal entry: Hood
The "V" in certain GM cover plates was an aid to lubing the outer axle bearings. The ring gear will throw lube up on the back cover. The "V" will direct the lube outward to the two holes in the housing. From there, it will go into the tubes and hopefully lube the bearings.
