1965 327 vortec heads/R700 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 07:57 PM
kevenj's Avatar
Panhead
I have a stock 1965 327 2 bolt main. 2 speed aluminum case powerglide. Will the 5.7 vortec heads bolt right up w/o any modifications or special equipment? What is the difference on the vortec 062's and the other 192's ?? Can I run 87 octane or do I need to run 92? Will a R700 automatic bolt up to the engine w/o any modifications or special equipment? PLEASE HELP A NEWBIE!!
Old 06-05-2007, 08:49 PM
DoubleVision's Avatar
Yes the vortec heads will bolt up, but they will require a vortec intake also along with self aligning rocker arms. There really isn`t much difference in the vortec castings, some say the exhaust port is better on one than the other however some web sites dispute this. If your 327 has flat top pistons you should be okay with pump gas. a 700R4 is a bolt in, but if you retain the lock up torque converter, you`ll need a painless wiring kit, and you`ll likely have to modify the crossmember.
Old 06-05-2007, 09:04 PM
A 700 requires a TV cable hookup.
Old 06-06-2007, 05:01 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Depending on what this is in the stock crossmember may only need to be moved but he will also need to shorten his driveshaft and change the yoke, the 700 is longer than a PG and has a larger yoke. A 200-4R is the same over all length as the '65 PG and uses the same yoke so would not require any driveshaft mods and should only need the crossmember moved back to where it would be positioned for a TH400. Of course there will be some shift linkage mods needed or a new shifter installed. Either OD is well worth the effort to swap though.
Old 06-06-2007, 06:51 AM
Mustangsaly's Avatar
vortec head info. the vortec head #s are 062 & 906
or
12558062
10239906
this might be a little on the extreme side but gives you the idea.
http://www.2quicknovas.com/vortecheads.html
Glasspacks on a 327 Vortec GunnerTHB Engine 19 02-04-2007 10:24 PM
Vortec heads on a 66 327 SBC jchav62 Engine 2 01-06-2006 11:47 PM
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
1965 327 engine cam retainers?? chattstorm Engine 3 02-14-2004 01:21 PM
vortec heads on a 327? 68redimpala Engine 4 09-28-2003 09:05 PM
