#1
1965 Chevelle SS Emergency Brake cable
I am having trouble with the emergency brake cable hanging up on my recently acquired "65 SS. Is this common on the 65, if so, is there some trick to freeing up the cable so I can have and emergency brake that works?
Register now (free) or login to remove ads |
#2
As a moderator here, I would like to WELCOME YOU to Hotrodders.com ![]() I owned a 65 Chevelle SS and did not have any problems with the emergency brake....but then..It was a NEW Chevelle ....I bought one new in 1965 .... I am not aware of that being a real trouble area for the Chevelles. It is very possible that some lubrication on the cable and the ratchet could fix your problem. Again....WELCOME Deuce |
#3
1965 Chevlle SS
Thanks for the replies. It appears that the E Brake pedal won't depress, I'm trying to find out if there is a cable that is stuck. I'm waiting for the shop manual, so I'm going to see if it's something obvious (don't we all wish for that!?)
Joebrake |
#4
65 Chevelle Parking Brake Assembly
to all,
I discovered my problem with the 65 Chevelle Parking brake. It appears that the Parking Brake assembly gear is not engaging. Quite common to have the teeth be stripped. So I'm looking for a used one (they don't re-pop them). Anybody know of or have one? thanks Joebrake |
#5
Maybe these will help you locate a pedal ..... http://www.hemmings.com/index.cfm/f...rch/type/pedals http://www.jrschevyparts.com/
#6
parking brake assemble
Thanks for the help in locating a parking brake assembly for my 65 Chevelle. I found one in a local salvage yard.
Now it needs a little detailing and painting and it should be ready for the car! thanks again for the leads, I'll file them for future use. Joebrake |
#7
Great man! Thanks for getting back with us.
| Thread Tools | Search this Thread |
| Similar Threads for: "1965 Chevelle SS Emergency Brake cable" | ||||
| 1965 Chevelle Malibu SS, to restore or not? | GMW | Body - Exterior | 19 | 12-01-2006 01:42 PM |
| Emergency brake cable end fix needed | jprimo | Suspension - Brakes - Steering | 2 | 05-16-2005 12:16 AM |
| Emergency brake cable que. | 39chevy | Suspension - Brakes - Steering | 3 | 10-19-2004 08:24 AM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
