1965 chevy c10 twin stick trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2011, 03:59 PM
hey guys ive got a 65 chevy c10 its my first vehicle im 17 and im slowly building it into a hot/rat rod ive been mildly building the 350 that was in it when i got it and now i want to pull the granny 4 and install a twin stick set up mostly for the cool factor, i dont know jack about what boxs i would need but if any of you guys out there have done this or have looked into to it i would really like to here what you got
Old 12-06-2011, 04:27 PM
Wiki Edits: 31
twin stick is just an auxillary transmission, but no common automotive or light truck transmission that will bolt to a 350 can benifit from an aux box. The ratios will be simmilar and ither will end up with a 1:1 in 4th.. Unless you put somthing like a 4-53 Diesel in it..
if it's just for the cool factor. couple an old 3spd to it. you could never be in the wrong gear
Old 12-07-2011, 11:14 AM
If its a mild 350; grab a saginaw 3 or 4 speed. Muncies and the hot rod T10s go for close to a grand and unless you know what you're looking at, you might end up with a box of junk. You can still get a box of junk from a saginaw, but its a much cheaper box of junk.
Do yourself a favor; don't build a rat rod; fix it right, use quality materials, some ingenuity and a lot of elbow grease. The main thing with your first hotrod is to actually get it on the road under its own go and whoa power, and where you dont let the smoke out. Once you can fix all of its systems, and you can afford a second car, take it off the road and get crazy with it if you want.
If you need saginaw hard parts (gears forks etc), you'll have to buy good quality used ones (I'll hook you up with some people if you get to that point). If you need an overhaul kit, PM me and I'll help a brother out.
Ask questions and listen to the guys who worked with this stuff when it was new. Find a Hayes or Chiltons or Motors manual that includes 1965. I like the old Motors ones best; because it covers more makes and models; this way if you get a 69 sag; it'll be covered. You want something with a 2.5 - 2.8 1st gear ratio.
Nate
Old 12-08-2011, 11:15 PM
im not trying to make it your average use what you got rat im trying to do everything right, so it will be ugly to the average eye but angelina jolie to guys like us
Old 12-09-2011, 07:26 AM
Thats the right way. Start a project Journal too.
Old 12-09-2011, 09:41 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i think that an aux gear box would be the right way
gear venders overdrive might have what you need, and you could keep the trans you have now
its not cheap though
1965 Impala How can I tell which trans is in the car? EazyDuzIt102 Transmission - Rearend 3 06-03-2011 09:42 PM
153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick. Classic Chevy Dave Engine 2 09-17-2010 03:44 PM
383 chevy stick flywheel 65ELCMO Transmission - Rearend 5 03-18-2010 08:23 PM
1965 c-10 230cid engine, trans swap questions hogring Transmission - Rearend 5 10-05-2009 01:03 PM
HELP! Can't get the trans dip stick tube in 67Camaros-n-BigD Transmission - Rearend 2 11-06-2005 07:42 AM
