Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 el Camino dash problems!!!
Old 01-08-2013, 12:43 PM
V8&4spd V8&4spd is offline
Last journal entry: It Will Work
Some of the gauge openings are standard size GM. You can use gauges from a 2nd gen F body if you want. You can also use different speedo readings all the way up to 160 mph.
