1965 elcamino front of motor ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2008, 04:39 PM
hello, i need some help with my 65, i just put in a motor and trans from a 67 , impala, my car is a air car and has power steering, it has the old double hump heads with no bolt holes on the front of the heads, im trying to put the alt., air and powersteering pump on, we put headers on the car, we no we got the power steering pump on right, it take the bracket, that puts the pump up alittle higher to miss thegear box, we can not find a way to put the alt. on with the pump where it is, does the air go on the pass side on the car and the alt. on the drivers side, we know we where proble going to have to make something to make it fit, but every way we put it its either to high cant close hood or way over by the finder , we are at a loss , need help bad, if any one has sovled this problem, or know where i can see a diagram or something, please help and thanks
Old 02-03-2008, 05:15 PM
MI2600's Avatar
Member# 3287
With headers, you're going to have to buy a bracket to mount the alternator on the left side. The bracket, if I remember correctly, bolts to the two front exhaust holes.
Old 02-03-2008, 05:56 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Can you post a picture or two?
Old 02-03-2008, 06:31 PM
pic
pic of the front of the motor or the car , what kind of bracket, where could i get one , is it the factory bracket , will that work with headers
Old 02-03-2008, 06:37 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Most all the header manufacturers make a mounting bracket for the alternator with headers. Here's an offering from Summit.
http://store.summitracing.com/egnsea...&autoview=prod
Old 02-03-2008, 06:43 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I saw some header style alternator brackets for a sbc at Auto Zone the other day.... You have to buy three pieces to make it work....one piece bolts to the front two header bolts on the drivers side...the other piece is adjustable and bolts to that piece...the third piece is the piece that braces the alt. and adjusts the tension.
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
emision loopholes digitalfrek Engine 13 03-13-2006 06:25 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
any one know the correct specs for a 72 elcamino front end? IHAVECHEVYPARTS Suspension - Brakes - Steering 0 11-18-2002 05:28 PM
