1965 F 100 Ford, swap engine from 6 to V8 with same transmission?
Good Evening:
I am considering purchasing a 1965 F 100 Ford Pickup with a 300 CI 6 cyl engine. I want to change the engine to a V8 with a bit more power. Can someone tell me what Ford V8 engine will bolt up to the existing 4 speed transmission and bell housing? Any and all help with be appreciated. Thank You John Steiner |
All I know about the pickup is the transmission is a manual 4 speed on the floor.
How can I identify the proper nomenclature of the transmission? |
T-18 4spd would have been what was there originally.. You can swap the 6 for an 8 directly with the right mounts. Same bell housing is also used..
However, the low RPM 6cyl is actually better suited to the T-18. All the torque is in by 2,500 RPM with a 300. EFI manifolds, 240 head and an offy 4bbl manifold and it'll wake it up, but still have that torque band |
You just need the right bellhousing, clutch plate, etc. An fe or a windsor small will bolt in with factory mounts. Any other ford v8 will work but the mounts may be a little trickier. Yiy could also go with a chevy v8.
| 1965 AMC Rambler American Engine Swap | imaginaryderek | Engine | 34 | 08-13-2012 03:33 PM |
| 1965 c-10 230cid engine, trans swap questions | hogring | Transmission - Rearend | 5 | 10-05-2009 01:03 PM |
| 95 ford F-150 engine swap, Same Transmission fit new engine? | F-150 | Transmission - Rearend | 5 | 10-07-2007 12:11 PM |
| ford 289 transmission swap | p.mckee | Transmission - Rearend | 6 | 04-25-2007 11:07 PM |
| Ford Transmission Swap | Ranger2346 | Transmission - Rearend | 1 | 10-23-2003 08:43 PM |
