Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 ford galaxie rear end?
Old 06-14-2012, 10:54 AM
Irelands child's Avatar
Irelands child Irelands child is offline
About the only way to tell without a tag for sure is to pull the chunk out and count the gear teeth. That accomplishes a couple of other things besides determining the ratio - it also determines the axle spline count as well as which, if any Equa-loc or in a few cases, Detroit Locker plus the condition. The standard rear end if you didn't specify something else on your order sheet was a 3.50 (my local dealer and I had a fight about that problem on my '65 w/390 PI, I ordered an Equa-loc with 4.10s - they had to do a dealer install )
