Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 gmc 305 v6 new clutch problems
Old 12-21-2012, 04:32 PM
Trophyman Trophyman is offline
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Can U run it through the gears without the engine running? If so, and it "grinds" with the engine running while trying to engage 2nd gear, I'm with widetrack. Sounds like problem with synchro. None the less, you should repair the bent rod under the dash. May not be fully depressing the hat.
