-   -   1965 gmc 305 v6 new clutch problems (http://www.hotrodders.com/forum/1965-gmc-305-v6-new-clutch-problems-227426.html)
klassickarman 12-21-2012 01:40 PM
Got a 65 gmc 305 v6....put a new clutch, pressure plate and throw out bearing and only grinds second gear...bent clutch rod under dash. Is that the problem??...but we can get 1st 3rd and reverse...any advice will b helpful!!
69 widetrack 12-21-2012 01:53 PM
Sounds like 2nd gear synchro's by the description.
Trophyman 12-21-2012 04:32 PM
Can U run it through the gears without the engine running? If so, and it "grinds" with the engine running while trying to engage 2nd gear, I'm with widetrack. Sounds like problem with synchro. None the less, you should repair the bent rod under the dash. May not be fully depressing the hat.
Crosley 12-21-2012 05:07 PM
I edited the thread title. We dont use : " Please HELP, HELP, NEED HELP" as thread titles here.
Please place proper information in the thread title. It helps the membership and the search feature on Hotrodders
QParker 12-21-2012 06:06 PM
I'd vote synchro's. The T90 in my Willys did the same, but in third. Learn to double clutch, it's cheaper:D
Trophyman 12-22-2012 07:17 AM
:thumbup:
On the double clutch.
