1965 gmc 305 v6 new clutch problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2012, 01:40 PM
Got a 65 gmc 305 v6....put a new clutch, pressure plate and throw out bearing and only grinds second gear...bent clutch rod under dash. Is that the problem??...but we can get 1st 3rd and reverse...any advice will b helpful!!
Old 12-21-2012, 01:53 PM
Faith - Respect - Trust
Sounds like 2nd gear synchro's by the description.
Old 12-21-2012, 04:32 PM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Can U run it through the gears without the engine running? If so, and it "grinds" with the engine running while trying to engage 2nd gear, I'm with widetrack. Sounds like problem with synchro. None the less, you should repair the bent rod under the dash. May not be fully depressing the hat.
Old 12-21-2012, 05:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I edited the thread title. We dont use : " Please HELP, HELP, NEED HELP" as thread titles here.
Please place proper information in the thread title. It helps the membership and the search feature on Hotrodders
Old 12-21-2012, 06:06 PM
QParker's Avatar
Six Offender
I'd vote synchro's. The T90 in my Willys did the same, but in third. Learn to double clutch, it's cheaper
Old 12-22-2012, 07:17 AM
Trophyman's Avatar
On the double clutch.
Brake conversion 1965 gmc imperial Suspension - Brakes - Steering 7 01-07-2010 12:54 PM
1965 GMC 1/2T Disc Brake kit ericehsbrown Suspension - Brakes - Steering 1 02-23-2009 05:20 PM
ID of manual 4 speed gmc year 1965 redneck25252000 Transmission - Rearend 2 09-06-2008 07:28 PM
1965 T-Bird A/C Clutch atlas4141 Electrical 1 08-14-2005 12:30 AM
1965 GMC Ambulance BONES2005 Introduce Yourself 1 07-30-2005 10:12 AM
