Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 GTO hard top, remove exterior trim
Old 02-16-2013, 09:04 AM
tech69 tech69 is offline
put up or shut up
you peel it off from the bottom edge, starting at the end and working your way to the other end. Here's a great video on it.
He uses a clip tool and they work good but can leave little dimples so you gotta be careful if you choose to use that tool.
