1965 Impala disc/disc - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2007, 09:34 AM
freedom53's Avatar
Last journal entry: A Few Years Later...
Used 1970 impala front dics set up and rears off a later 70's w6 firebird. I am using the firebird disc/disc m/c , an adjustable prop valve and want to know what I should be using for a brake booster? As well, does any body know of a rack and pinion setup that would work with this huge vessel?
Old 11-06-2007, 09:02 PM
stoneshrink's Avatar
Buickguy
Last journal entry: And now the new project
Do you have sufficient vacuum to run a vacuum booster? Really, the whatever fit principle applies. My 54 Studebaker has GM running gear and I used a double diaphram booster with it simply because it was the only thing that fit..... the brakes work very well... sometimes too well because the motoor makes great vacuum.
1965 Impala -- suspension/wheel question(s) dukeplaysbass Suspension - Brakes - Steering 6 07-09-2007 10:33 PM
Transmission Problem 1965 Impala EazyDuzIt102 Transmission - Rearend 15 08-02-2006 07:15 PM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 05:52 PM
1965 Impala SS wheel well molding mweber Body - Exterior 3 12-28-2003 08:11 PM
1965 impala bent bumper help? impala65 Body - Exterior 2 08-22-2003 07:50 PM
