Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 Impala Front End Suspension Problem
Old 03-29-2004, 12:21 AM
jimfulco jimfulco is offline
Heat can mess up the springs. I bought some Nova springs (same part # as the old ones) from GM a few years ago & they sent big-block springs (for a small-block car). Said the part # was superceded. Yep it sat too high. The local spring shop torched them & got it down to the right height. Within a few months, they had sagged & dropped it down another 1-1/2" or so. Did the shop that did the work order the springs? If so, they should fix it and not charge you.
