1965 Impala Rack And Pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2008, 10:38 PM
freedom53's Avatar
Last journal entry: A Few Years Later...
Anybody got any ideas for a donor vehicle?
Old 01-20-2008, 07:34 PM
Last journal entry: my twins
rack n pinion
whats wrong with just addind power steering much easier upgrade
Old 01-20-2008, 09:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
You should read this wiki article about swapping in a rack and check out the link to Longacre racing that is there.
http://crankshaftcoalition.com/wiki/...inion_steering
longacre racing article.
http://www.longacreracing.com/articles/art.asp?ARTID=13
It is much more work to install a rack than just making mounts. There IS some engineering required. Changing your steering geometry without knowing what those changes will cause can make your car VERY unsafe.
Later, mikey
BE different....ACT normal.
Old 01-20-2008, 09:23 PM
rack n pinion
thanks for the web site vey interesting material, i like challenging jobs but this one requires a lot of homework about all i can offer you in probably original alignment specs on your appliction.
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 10:24 AM
Triumph tr-3 worm box swap with rack and pinion lugog Suspension - Brakes - Steering 1 06-29-2007 03:12 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
Rack and Pinion Conversion for a '73 Impala? hduff Suspension - Brakes - Steering 2 10-02-2004 08:47 PM
Mustnag II rack and pinion Echofive Suspension - Brakes - Steering 3 05-26-2004 06:26 PM
