1965 Impala ss 283 Oil problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2009, 10:19 PM
Just partially rebuilt (new rings/heads/lifter/timing set) a 283 for a 1965 impala ss restoration project. Heads were done by a local machine shop. Put engine back in fired it up ran good except no oil in the passengers side head!(pushrods) pulled intake off to investigate everthing appears good. to my inderstanding oil is delivered to that side by the distributor?? Should the distributor cavity be full of oil when i crank the engine?? possible worn distributor? i dont know what else to do. WHen i crank the engine there is not alot of oil in the distributor area?
Old 07-19-2009, 09:44 AM
no oil
oil is delevered throught the push rods.check to see if they are clear. did you instal new oild pump. i use hv pump in them years.let me know if it helps
Old 07-19-2009, 10:08 AM
oil is not getting to the lifters
Old 07-19-2009, 04:28 PM
if your not getting oil . bad oil pump, bad cam barings or instaled wrong or bad cam look at botem of lifters to see if they are cuped. what kind of oil presure do you have? what kind of oil did you use for brakin?
Old 07-19-2009, 04:40 PM
getting oil on drivers side, new pump, lifters new good, 10w-30
Old 07-19-2009, 04:42 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Did you change the cam bearings? Cole
Old 07-19-2009, 05:37 PM
no, i did not
Old 07-19-2009, 06:56 PM
RSM's Avatar
RSM RSM is offline
Oil problem
You may want to check and see if you have an oil galley plug that has come loose on the front of the block. You have oil to one side so bearings and pump and lifters arent your problem. There may also be something plugging the oil galley that feeds oil to the lifters.
Touch up paint for 1965 Impala SS Rear End Side Moldings? Dill-the 65ImpSS Body - Exterior 1 09-14-2008 03:02 PM
1962 Impala SS ? kgard Hotrodding Basics 4 05-30-2008 09:21 AM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
Oil Pressure Problem? MartinM Engine 2 10-16-2002 02:52 AM
