Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 impala tail lights
Old 03-02-2013, 02:13 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
If the rear signal lights are working, the problem must be somewhere up under the dash/fusebox area....Signal lights and brake lights use the same part of the rear 1157 bulbs......I am reall suspecting the connection at the fuse box.......The fuse box splits in 2 halves on each side of the firewall.....make sure it is pushed together. There is a bolt that goes through the center of it to hold it together
