-   -   1965 impala tail lights (http://www.hotrodders.com/forum/1965-impala-tail-lights-230214.html)
Jason1965 03-02-2013 01:44 PM
I've just bought a 65 impala , and I drove it home , went somewhere the next day , and when night fell I noticed my tail lights are not workin nor the brake lights , the head lights work , I looked under dash and I can't believe all the wiring this guy has done , can any one help me figure out how to get them back workin , they was fine for a day , then nothing , the guy had the fuse box hanging taped up in all kinds of wires , I just don't know where to look , did I hit somethin with my foot , or any body have any suggestions on how to get them back working , thank you , Jason
poncho62 03-02-2013 01:59 PM
If neither the tail or brake/signal lights are working, I would suspect a ground at the back or maybe the whole harness is cut. I would start at the lights with a tester and work your way forward.
On those cars, the taillights are on the same circuit as the dash lights. Are the dash lights working?
Maybe the connection at the fusebox has been knocked apart, since he has it held with tape....just a couple of guesses
Jason1965 03-02-2013 02:02 PM
Yes the dash lights are all working
Jason1965 03-02-2013 02:07 PM
And looks like the rear tail light wiring is new , so get a test light and start from there to under the dash ?? The head lights work and there's also a voltage gauge that I noticed is not workin no more , but the turn signals work in the back just no tail or brake light , man idk , I'm not that good at electrical but ill go and look and see what I can ????
poncho62 03-02-2013 02:13 PM
If the rear signal lights are working, the problem must be somewhere up under the dash/fusebox area....Signal lights and brake lights use the same part of the rear 1157 bulbs......I am reall suspecting the connection at the fuse box.......The fuse box splits in 2 halves on each side of the firewall.....make sure it is pushed together. There is a bolt that goes through the center of it to hold it together
Jason1965 03-02-2013 02:21 PM
Ok I'm looking right now ill re post what I see , thanks man , for real !!!!!
poncho62 03-02-2013 02:26 PM
Wiring diagram.....maybe you can blow it up and print it
http://www.antechlabs.com/K0GFM/wd.jpg
Jason1965 03-02-2013 02:30 PM
Right on man , I'm moovin the car in now where I can work on , and look at that fuse box , ill MSG back and tell ya what I see , thanks alot for the diagram !!!!
EOD Guy 03-02-2013 05:42 PM
If the dash lights are working...... The fuse box is prob connected. Get a test light and test the brown and yellow wires at the tail lights.
If they have power...... it's a bad or corroded socket or the ground is bad. I'd clean the ground and sockets 1st and retest.
If they don't have power........ Find the brown and yellow wires under the dash, I'm not sure, but they should be run behind the driver's side kick panel. follow them all the way to the light switch, and brake light switch, looking for any breaks etc........ then using the test light, check the output from the light switch and brakelight switch. if you have power out of the switches...... you have a break in the wires leading to the rear of the car.
If they don't have power...... Use your test light and check the fuses. If they have output it's either the feed wires from the fusebox.
If they don't have power...... disconnect the battery and pull the fusebox apart and make sure the terminals are still connected on the back side of the box
I don't think it's the fusebox, because your dash lights work.
Jason1965 03-02-2013 05:49 PM
65 tail lights
Yes I agree , I got them on , the guy I bought it from has just made a mess of wires under there , he has a newer style 10 amp fuse on the wire to the original fuse box , so ofcourse it was fried , I put a 25 amp in there and there back on , so I gotta re wire it right soon , but thanks for your input I really appreciate it!!!!
