1965 L-77 turbofire 283/220 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 10:17 AM
defilade's Avatar
2012
can this engine be bored safely to 4.00?
Old 06-28-2010, 01:11 PM
327NUT's Avatar
Safely???? I would first have the block sonic tested to see if there has been a core shift. If not then have a VERY GOOD machine shop do the work. Back in the day a lot of guys were building "301's" with the 30-30 Duntov cam and vette dual quad intakes.....hot set up then. Personally I wouldn't take it out that far, punch it .060 to a 292, you'll never know the difference and you'll still have some "meat" left in the cylinders.
Old 07-02-2010, 10:02 PM
defilade's Avatar
2012
sweet thanks i want to put a manual trans behind it what do you recommend?, thank you
Old 07-02-2010, 11:55 PM
327NUT's Avatar
All depends on your budget and if you want an O/D. If you could locate a 5 spd out of a newer 1/2 ton pick up.......or one of the old 4 spd muncies.
1965 chevelle ss 454 swap (FUJIMO 2) FUJIMO454 Hotrodding Basics 1 05-11-2009 06:18 AM
What Kind is this? BarryK Suspension - Brakes - Steering 3 09-03-2007 04:06 PM
April Car Craft with 77 nova 78novaman Hotrodders' Lounge 15 03-28-2005 09:12 PM
1965 Skylark Chevy Swap 65skylark Engine 0 05-24-2004 12:23 PM
77 ford femadorob420 Suspension - Brakes - Steering 1 01-01-2003 05:11 AM
