1965 Muncie M-21 4-Speed: No Drain Plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 04:52 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
What's the best way to drain the old lube out of a M-21 Muncie? No drain plug, anybody got a home made remedy, short of removing the shifter, removing the front 4 bolts and rotating the transmission 90 degrees?
Thanks.
Old 04-07-2013, 05:50 PM
Banned
they have an electric pump and you can suck it out the fill hole. they are about 25 or 30 bucks Autozone, walmart.
Old 04-07-2013, 05:54 PM
Banned
also you can drill it tap it and install a drain yourself.
Old 04-07-2013, 06:57 PM
RWENUTS's Avatar
Turkey baster dude!! Stop laughing!! I'm serious!!
Buy a big baster for 5 bucks, put a vac hose on the end and go fishin'.
Old 04-08-2013, 10:46 AM
they have suction guns you can get to 'insert' and remove fluid. Turkey baster would work, but you may have trouble getting sufficient fluid out. Original style Muncies (that have the revrse threaded nut) work best with 1 quart of a GL4 NON Synthetic 75w90 such as Sta-Lube #SL24229 from Napa. Race guys use Royal Purple MaxGear 75w90 or RedLine MTL(?). I usually only recommend the Sta-Lube or MAX GEAR (not RP's "synchromesh").
Here's what I use at home; got mine from Grainger for twice the price years ago
Google "16oz oil suction gun" Chi-com Freight has them for under 20 bucks. (Harbor Freight)
Old 04-09-2013, 12:49 PM
Excellent. Napa's got em for about $20...
Thanks for your help!
Old 04-09-2013, 01:09 PM
you'll find all kinds of uses for it really. no problem
Old 04-10-2013, 06:46 AM
For future thread surfers here's a link to similar thread: muncie fluid change with no drain hole
Autogear: You still recommending using only (1) quart of GL-4, instead of filling it up to the drain plug with 3 pints?
What is this drain plug ? 64Joker Engine 1 08-15-2012 03:05 PM
muncie fluid change with no drain hole sapsz28 Transmission - Rearend 9 10-21-2011 09:53 AM
7/8-16 Oil Drain plug? Simplicity Engine 3 08-12-2009 07:55 AM
9" drain plug Javelin69 Transmission - Rearend 2 10-03-2007 09:00 PM
Aftermarket Drain Plug MI2600 Transmission - Rearend 12 08-15-2006 02:07 PM
