1965 mustang 302 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-26-2007, 03:20 PM
1965 mustang 302
Question,
I have excessive valve train lash.
I am using a Lunati cam and lifter set along with lunati valve springs, stock rocker arms, stock 302 heads, and stock push rods. The rocker arms are not adjustable and my valve stem height is set to specs. I have verified with the local Mustang parts store my push rods are correct ( They matched them up with another set they had in stock) What could be the problem?
My lifters are hydraulic non roller.
Old 03-26-2007, 04:46 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome....This is the Introduction forum...it would be best to ask your question in the Engine forum...that way the guys that have the answers will see it.
Old 03-27-2007, 01:52 AM
aka Duke of URL
You have incorrect valvetrain geometry. Go to the COMP CAMS website and it will be explained.
NOTE- You do not need adjustable rocker arms.
1965 Mustang Sitting since 1988 kuhn-77 Engine 9 03-06-2007 10:51 AM
302 swap in a 94-95 mustang luidmax General Rodding Tech 4 01-08-2006 07:37 PM
1965 Mustang Seats 65Stanger Interior 1 10-26-2005 11:44 AM
1965 mustang GT 350 akm General Rodding Tech 7 01-26-2004 09:04 PM
Transplant 302 and AOD tranny into 80 mustang bildo95 Transmission - Rearend 1 08-26-2002 09:47 PM
