1965 Mustang 7 3/4" ring and pinion. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2002, 04:07 AM
Post 1965 Mustang 7 3/4" ring and pinion.
I have a 7 3/4" ring and pinion 2:80-1 in my car, is it possible to put in a 8" ring and pinion as I can not find any listings for a 7 3/4"? <img src="confused.gif" border="0">
Old 12-15-2002, 04:33 AM
aka Duke of URL
Thumbs up
Yes. The 8" ring and pinion is used for service.
Old 12-15-2002, 05:52 AM
Post
Thank you for the quick response and I hope you mean, by service, that I can replace the ring and pinion with any standard 8" ring and pinion? I want to replace it with a 3:73 or 3:83 and my axle splines are 28 tooth.
Old 12-15-2002, 06:12 AM
aka Duke of URL
Thumbs up
Yes again. I should have been more precise. The 8" actually stared as a 7 3/4" and the 9" actually started as an 8 3/4". Both were upgraded as time went along and the 8" ring gear will bolt to your case.
Sorry about that.
Old 12-15-2002, 06:41 AM
dmorris1200's Avatar
doesn't play well with others
Post
We'll let you slide this time KULTULZ, but let's not let this happen again!
BUILT FORD TOUGH
Old 12-15-2002, 07:15 AM
aka Duke of URL
Red face
[quote]Originally posted by dmorris1200:
We'll let you slide this time KULTULZ, but let's not let this happen again! <hr></blockquote>
Do you mean the Duke might get crowned?
<img src="graemlins/spank.gif" border="0" alt="[spank]" />
Old 12-15-2002, 12:55 PM
Post
[quote]Originally posted by dale634:
<strong> I want to replace it with a 3:73 or 3:83 and my axle splines are 28 tooth.</strong><hr></blockquote>
I believe that the ratios you listed are not available from FOMOCO.
Anyhing more than a 3.55 is aftermarket. And limited slips are like chicken lips.......hard to find.
