Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1965 Mustang vent window frames
Old 04-29-2013, 08:20 PM
Lizer Lizer is offline
I'm not sure what your question is...are you trying to remove the vent window then?
That bolt at the bottom there in your picture is an adjustment screw. I have a 67 so yours might be a little different mine, however on the door panel side you should have access to the head of that bolt. It might have an allen head with a hex lock nut around it. It should screw right out, and the vent window will lift up out of place.
