1965 oldsmobile cutlass rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2011, 12:35 AM
Picked up a 1965 oldsmobile 10 bolt rearend this weekend. it's set me back a 150 dollars but it is a posi model and seems to be all there, when I got it home water came out around where the pinion yoke goes, but I took the cover off tonight and the everything inside is greased up so I'm guess the unit will turn I'm going to drop the brakes tomarrow and check it out.
I plan on getting new bearings put in and redoing the brakes and lines anything I should look for while I'm tinkering around?
thanks again
oh, what do I use to clean the inside of the unit out without taking everything out of it?
Old 09-19-2011, 04:52 AM
willowbilly3's Avatar
Last journal entry: Body mods
Many years ago when I had a 66 model, I read that the Olds 10 bolt was an odd ball and not the same as a chevy. I also read there were some parts that were hard to find for them. Good luck.
Old 09-19-2011, 08:45 AM
SSedan64's Avatar
Other than wiping out the Buildup/Crud, you can use 'Brake Clean'.
Some 10-Bolt Info > http://www.oldsmobility.com/old/10bolt-tech.htm
1992 oldsmobile cutlass bogging out metallica82010 Hotrodding Basics 3 07-26-2011 02:35 PM
89 oldsmobile cutlass ciera Medz Introduce Yourself 3 08-13-2008 08:21 PM
1956 Oldsmobile Rear Axle Ted's37 Transmission - Rearend 7 04-17-2004 08:28 PM
1965 oldsmobile jetaway 2 speed automatic coilpac6567 Transmission - Rearend 2 12-05-2003 12:43 PM
Rear end from a 71 Cutlass medicdogg Transmission - Rearend 1 11-17-2002 01:59 AM
