-   -   1965 T-Bird A/C Clutch (http://www.hotrodders.com/forum/1965-t-bird-c-clutch-67044.html)
atlas4141 07-30-2005 11:18 AM
I am trying to help a friend find a A/C clutch. The car is a 1965 T-Bird, with A/C compressor # C35A-2875-AZ, model HG1000. He needs the A/C pulley with built in coil. The pulley is 6 3/4 in. and is 3 1/8 in. from mounting plate to center of belt groove. After market parts have not been any help. ( He works at a NAPA store) New or good used clutch or compressor/clutch will work. This car is 100% resto. so a conversion to newer compressor is not really the answer. Any help as to where to look would be great.
KULTULZ 08-14-2005 01:30 AM
Sorry, I just came across this post. By your description, it sounds like an EATON clutch rather than the BORG-WARNER. Do you see any stamping nos. on the clutch itself (example C2AA-2981-A)?
If you still need the clutch, let me know and we will find you one.
