1966 350 swap in nova 2 oilpan problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2003, 04:30 AM
New Member
Unhappy 1966 350 swap in nova 2 oilpan problems
i am in the process of completeing a 350 to go in a 66 nova 2 four door (sleeper)and i am lost on this oilpan deal why does it require such an expensive pan and are there any ways to get around the special pan i need help of an expireanced swapper thanks <img src="confused.gif" border="0">
Old 04-20-2003, 04:54 AM
dklong's Avatar
Post
on GM the steering linkage is in front of the engine cross member,except for chevy2 its behind the cross member, which requires a front sump oil pan and oil pump pick up. you need this oil pan too clear the steering linkage.
Old 04-20-2003, 06:26 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
You can measure the block to the nearest part in the front and rear and find a pan that way. They list the depth that way in mose catalogs.
Luv the smell of NITRO in the morning.
Old 04-20-2003, 07:26 AM
jalopy45's Avatar
Cool
Check the Moroso catalog for the oil pan, also check the various Nova web pages have seen original pans for $30-50.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
