1966 belair V8 engine frame mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2010, 03:02 PM
Hello.
As I am swapping my L6 engine for a SB V8 I'm in need of engine frame mounts for the V8. They seem nowhere to be found and I plan to build me a pair of mounts myself. But I don't have a clue what they should look like since I have no V8 car to look at and can't find any pictures of them. I don't even know how many or witch of the six holes (on each side) in the k-member to use for a sbc installation.
I know it's hard to try and explain this, but give it try if you know something about this (i.e. height and some kind of measurment from a fastener bolt to connecting bolt hole). A picture of a 65-66 full size chevy engine frame mount for V8 could also be very helpfull, especially if its in car.
Of course I'm also interested if anybody know where to buy these mounts.
Thanks/Jesper
Old 09-25-2010, 03:29 PM
SSedan64's Avatar
These are from RockAuto>> http://www.rockauto.com/catalog/moreinfo.php?pk=314932 they fit numerous other GM cars if you click on the higlighted Part# in catalog it will show the list.
http://www.rockauto.com/catalog/raframecatalog.php
Old 09-25-2010, 03:48 PM
Yes, thanks, but that is the part that mounts on the engine, right?
I'm in need of the on the ones that mounts on the frame. There should be no rubber, just a stamped steel bracket.
I've found a picture now that shows that they should bolted in the upper holes in the frame, but the hard part is to know how high they need to be.
Thanks/Jesper
Old 09-25-2010, 03:54 PM
SSedan64's Avatar
Yes those are engine side. The list will give you an idea of other Frame stands that will work tho'. May fing something on Ebay..
Old 09-25-2010, 03:57 PM
poncho62's Avatar
Wiki Edits: 5
Dont know if you have scoured a few junkyards yet, but that would be the route I would take....With any luck, there would be a shell with the engine gone. I would think 65-72 would be pretty much the same.......I think
edit....just noticed you are in Sweeden.....Pickings might be slim......I think the Pontiacs over there are the same as here in Canada......Chevy frame and engines......might help a bit
Old 09-25-2010, 04:40 PM
Oh, okay. I belive a stand from anything else then a B-body will not fit the frame at all though. Not the same height and different bolt pattern. And older impalas seem to have a four bolt pattern.
Strange thing is that I've been searching ebay for months without any luck.
Thanks/Jesper
Old 09-25-2010, 04:50 PM
Yes, as you said pickings here are slim, also on Pontiacs. Maybe I try contact some junkyards in the states and see if I have any luck.
Then again It would be an easy part fabricate by your self, if you had some measurements to go on..
Thanks/Jesper
Old 09-25-2010, 05:10 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by hefferzon
Hello.
Thanks/Jesper
Hello Jesper, I feel for you, having to collect American parts in Sweden. It must be very difficult. Whenever I'm adapting one thing to another thing, I bolt on the stuff that I know I will need and then build whatever conglomeration of steel onto that to make it work. In other words, I might bolt on the rubber motor mounts to the block, bolt a round steel tube to the rubber motor mount, then use whatever steel sheet or plate I had to to in order to reach from the steel tube to the frame of the car, once I had the frame level and the motor positioned in the engine bay and chocked up so it couldn't move, then cutting out pieces and fitting them in to tack weld them a little at a time until the piece was built. Then I would pull the motor out to finish welding up the stands. Here is an example of a stand from Speedway Motors that might look something like I would have constructed when I got through.....I've done it that way on many, many oddball engine swaps....Not that yours is an oddball, just that you can't have parts overnighted to you like we can in this country, so you may have to build your own....
http://www.speedwaymotors.com/Univer...unts,1905.html
Here are the rubber mounts that bolt to the block.....
http://www.speedwaymotors.com/Small-...unts,7959.html
Old 09-25-2010, 06:47 PM
Last wiki edit: Removing stuck fasteners
Engine mounts (home maded)
In my 40 chevy sedan with a 350 350 th trans., I installed the transisson then set the trans. on it and leveled the carb, left to right and front to back and fabricated to fit. first I checked the drive shaft and found one that would fit, I had to move the engine forward about 1/4 inch to make the drive shaft fit with the same clearance that my pickup with a 2 piece shaft had. It worked great.
P.S. I used an electric fan which set close to the rad, and sucked air through with plenty of room for the water pump. Might have used the short water pump, I not sure. lol
Old 09-25-2010, 07:29 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I know where there are a few sets of these---v8
But, I cannot get to them 'til probably after T-giving.
Been doing a bit of 'road warrioring' and I think I will be
out all of October and some of November.
I might be able to buy them and get them to you
Old 09-25-2010, 09:34 PM
ericnova72's Avatar
More for Less Racer
Have you tried directly calling some of the restoration company's like Year One, Impala Bobs, etc?? Some of them have used parts sources or their own used parts yards, stuff that isn't listed in their new parts catalogs or in their online site.
I know J & W Nova Parts is this way, they have their own salvage yard just for Nova parts, catalog just mentions it in the back and to call with your needs.
Old 09-28-2010, 02:46 PM
Thanks everyone for your help. I will try e-mailing some restoration companies and wreckers and see if can find anything. And if there no luck I build me a pair of brackets.
Thanks/Jesper
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
fab gmc 250 engine mounts? 31chevy Engine 2 02-09-2008 06:02 PM
Need Quick Help Plz - Engine Mounts Hot_Rod_Faith Engine 3 01-09-2004 09:52 PM
Nova Frame Motor Mounts........ bg Engine 0 01-05-2003 03:17 PM
