Maybe I didn't understand your question. Did you want to know if you could put the posi from the '66 in a G body rear end, or did you want to know if you could put the complete '66 rear end in the G body? You can not put the posi in a G body rear end. You can put the complete rear end in the G body if you want to do all of the fab work that's required to make it happen. I'm sure that the '66 rear end is quite a bit wider than the G body rear end.
