-   -   1966 buick riviera posi question (http://www.hotrodders.com/forum/1966-buick-riviera-posi-question-191300.html)
cutthroatkid 01-24-2011 01:36 PM
Hey guysd just wondering I have a posi sitting in my shop out of a 66 buick riviera is there anyway to make it work in my g-body?
big gear head 01-24-2011 08:52 PM
Nope, completely different rear end.
cutthroatkid 01-25-2011 01:06 AM
Just wondering seeings a body rear ends&fox bod rears can fit with some fab work was hoping I could get lucky :)
big gear head 01-25-2011 09:11 AM
Maybe I didn't understand your question. Did you want to know if you could put the posi from the '66 in a G body rear end, or did you want to know if you could put the complete '66 rear end in the G body? You can not put the posi in a G body rear end. You can put the complete rear end in the G body if you want to do all of the fab work that's required to make it happen. I'm sure that the '66 rear end is quite a bit wider than the G body rear end.
