Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1966 Chev PU upgrade to dual master cylinder for existing brakes
Old 10-21-2002, 07:52 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
the bolt holes are different where the master bolts on,do some slot work and the length of the rod has to be changed. then you have to mount the multi valve to something ,run a wire to it if you want an idiot lite . then its regular plumbing on the lines
