Never mind, upon further inspection the rear end will bolt right up no problem. He had it on his 66 but it was off of a 69 so it has the perches for the pig tail springs already.
Thanks for the replies though......
For future refference a 64 to 67 rear end in a chevelle is slightly narrower than one for 68-72. They still bolt in the same. They are great if you want to use slightly wider tires, gives you a bit more wheelwell space.
Ontario Rodders |
Thanks a lot, yes, I knew about the narrower length but I didn't mind that. I actually have 275/60/15's back there now and I figured I could squeeze 295's with the narrower rear end. That's ok, the 275's are pretty stout as they sit.
