1966 Chevy C10 stuck pilot shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2011, 12:48 AM
I really fouled this one up. Can someone give me advice on how to get an old SM420 unstuck. I installed a new clutch disk, flywheel and pressure plate along with a new throwout bearing and pilot bushing(brass or bronze alloy). I didn't realize when I installed it that the pilot bushing was too small for the pilot shaft. I tightened the bolts down on the transmission to bell housing and now the shaft is stuck in the pilot bushing. I figured this out because when I engage the clutch the transmission doesn't disengage. The yoke keeps turning. (I have the drive shaft out of the truck) The yoke only stops moving when I put the tranny in neutral. I've removed the four bolts holding the tranny to the bell housing but the trans wont came out. It only moves out about a sixteenth of an inch. It's going to take a lot of force to pull that pilot shaft out of the smashed bushing. Any advice is appreciated.
Old 06-19-2011, 10:54 AM
S10xGN's Avatar
Gotta love a turbo!
Put a jack under the trans and use a pry bar EVENLY a little at each bolt lug until you work it out. As it comes out, you might need to add thin wood blocks to make up for the size of the gap.
Note to self: test fit everything before forcing an install.
Russ
1966 Chevy II KW1152 Transmission - Rearend 4 08-25-2007 02:17 PM
1966 chevy c-10 warwickkid Introduce Yourself 1 05-25-2006 10:51 AM
1966 chevy c10 chevyc10 Engine 1 09-11-2005 08:26 PM
Drive shaft stuck in tranny? Deadtemple Transmission - Rearend 1 10-18-2003 08:26 PM
Stuck pilot bearing in 350 sbc I got it! zachscc Engine 3 12-23-2002 06:48 AM
