1966 cobra kit car, steering colum?
what kind of steering column are you using?
1966 corba steering!!!
Yes, you are right I have not used this before. I figured when or if someone replies I would answer questions they would ask rather then guessing what what info they wanted.
The car uses the fox body type suppension (1988 +-) and is using a rack. As for a shaft/ujoint we can make as needed. We were wondering what column or type as to have a starting point. I seen some used Vega's but not too interested in using that. |
Column
You also must have clearance for the shaft you would like to have it as straight as you can. So you have to measure how far your column can go into the engine bay, and clear exhaust, engine ETC. To give you any idea what to use we have to know how long the column can be, so we know a range of cars to work on, we also need to know about the shifter, would you want a Ford column over a GM, You have to help us out here. We could guess all day and not get it right. Most of the guys don't have cobra's, so we don't know what range to start in. Once we know we can get just about any thing done, And if we were building it ourselves, many of us would go to the u-pick and find it. Bob |
1966 cobra steering
Would like to use Ford stuff. 5 speed manual Trans. From the wheel to firewall is 27 inches. Would be nice to have 6 to 7 inches after fire wall and that would give us a nice shot to the steering gear./
Column
Using a Ford you have Pinto, Mustang, T-Bird, MXK, to give you an idea I only have a 22" column in my 46 Ford, like I said before I have a 87 T-Bird in my 33 Ford, which I think is longer than 22". My 46 had a Gm column in it that was 38", it stuck so far out from the dash that I could hardly get in the car. Bob |
1966 Cobra Steering
There is lots of room once the column goes out of the firewall. Up and down there is about 4 inches on either side when it is where it needs to be.
Now to the fire wall, from where the wheel needs to be, at the wheel to firewall it is a good 27 inches so that part is important. As far tilt, either way is ok |
cobra build
Check out the CLUB COBRA web site and their forums. Originals and kit or replica's there. Another consideration is how much foot room you will have if the kit is close to an original. On the originals your feet were a little bit sideways., not much room. Factory Five Kits using the Fox Mustang parts also have a website, Later FFR kits have more foot box room. Some kits furnished a welded steering shaft extension DON'T USE IT> As 35 ter- says buy a new DD shaft and if you don't need a U joint at the connection you can buy the no U joint connector. I have a couple Tilt and Telescoping Caddy columns in my parts stash.
1966 Corba Steering
Ok, thanks will take all of the info into account. May get back with you on some of your parts stash
Stash
Stash is for the some day projects . every once in a while when we need more room junior says are we ever going to use this and then puts it on craigs list. A friend owns a wrecking yard and when He is crushing cars we help him and trade for parts and any parts on the cars with the big red X are free to us. so we grab things we might use someday.
steering column
Timothale, had a good suggestion there with the other sites. One thing I like to put my wheel as close to the dash as I can and still tilt it, and have clearance. the length will depend on the angle, the biggest thing is, nothing is in the way, and get it as straight as you can.
Bob |
| tilt steering colum | Daimon DeLeon | Suspension - Brakes - Steering | 2 | 03-23-2011 08:30 AM |
| steering colum? | 49fordp/u | Suspension - Brakes - Steering | 4 | 04-09-2010 11:05 PM |
| steering colum | tsw27 | Engine | 1 | 12-13-2004 12:15 PM |
| 1966 buick steering colum help needed | stea | Suspension - Brakes - Steering | 1 | 01-17-2004 07:25 PM |
| Need a steering colum for my 89 camaro | KentuckyCamaro | Interior | 2 | 11-10-2002 03:11 AM |
