1966 Impala brakes not grabbing a well as they should - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2011, 08:34 PM
Brandonion1985's Avatar
When I hit my brake it isn't grabbing as tight as it used to. Checked the fluid level and vacuum hook up on booster seems to be right. Noticed an air sound when I press pedal coming from that rubber thing behind pedal. Anyone have any ideas what this could be and why my brakes are not grabbing right.
Old 06-30-2011, 09:09 PM
Your power booster has failed if you are hearing air when you press the brake peddal.
Old 06-30-2011, 09:29 PM
Are those expensive?
Old 07-01-2011, 11:11 AM
Mk1 Mk1 is offline
http://www.impalas.com/brakes/power-...ster-assembly/
http://www.impalabrakeparts.com/products.asp?cat=12
Those were just the first two links to come up when I google'd "66 impala power brake booster". I would do a bit more investigating before you run out and buy a whole new booster however.
1966 impala chopperdave70 Hotrodders' Lounge 16 01-22-2009 05:47 PM
disc brakes on a 1966 impala chopperdave70 Suspension - Brakes - Steering 2 05-03-2008 09:53 AM
Grabbing Brakes Maverick Suspension - Brakes - Steering 4 06-14-2004 07:12 AM
grabbing brakes ian marsh Suspension - Brakes - Steering 3 09-06-2003 01:03 PM
Brakes Grabbing!! Dave E Shank Suspension - Brakes - Steering 3 04-30-2003 05:47 PM
