1966 Impala radio dash hole cut slightly to big - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2011, 03:36 PM
Brandonion1985's Avatar
recentally just installed a cd player in my impala and I seem to of cut the hole for the radio slightly crooked and its too large in a couple places leaving gaps. What can I do to fix this have a pic to show the issue but its on my phone will post later
Old 05-13-2011, 07:23 PM
It's a sin to cut a dash for a radio.Just kidding.What you can do for a quick fix is go to the auto zone or what ever strore and get some of that door edge chrome plastic and put around the hole,cut it at a 45 degree angle so the corners will fill in.May look a little bright but will beat the alternative.
Old 05-13-2011, 07:30 PM
Thank you will give it a shot. Radio fits in just don't look too pretty. Felt bad cutting it myself but the plastic holes where the knobs for the old radio were located were kinda cracked too so dash wasn't perfect. So basically make a frame for the radio out of the chrome door stuff. The worst part is my cut want quite straight so it looks goon in one place then there's a gap in other spots.
Old 05-13-2011, 07:35 PM
Old 05-13-2011, 09:10 PM
DanTwoLakes's Avatar
Wiki Edits: 22
If you want to fix this so it looks terrific, you can cut a piece of plastic to fit the outside edge of the large flat opening with the vertical lines, cut a better correct size opening for the radio, cover it with your choice of material and then install the stereo. Nobody will ever know you made a mistake.
Old 05-13-2011, 10:26 PM
wp442's Avatar
Last journal entry: Feb. 03, 2006 - Bed repair 05
WOW! What did you use to make the cut....a chain saw?
Old 05-13-2011, 10:28 PM
I did use a small saw lol but other issue was some of the plastic was brittle and just chipped away.
Old 05-13-2011, 11:54 PM
Wiki Edits: 31
To add to this, a Ford single din installation kit will have a plastic peice that will look nice
Old 05-14-2011, 07:05 AM
Wiki Edits: 22
You could also do this with a piece of aluminum.
Old 05-14-2011, 08:02 AM
OLNOLAN's Avatar
Faceplace trim surround
I did this too in a motorhome. It wasn't that the cut was so crooked as it was the fact that the Alpine face plate trim was so narrow.
They make a thin aluminum trim ring thats black anodized for this purpose. I got mine at an independent car stereo shop. You have to go to the places that do custom installations. The big box stores I went to were absolutely no help as they use kits for their installations. The fellow at the custom shop new exactly what I needed, he only charged me $5 and I would have payed $20.
Old 05-14-2011, 08:45 AM
Wiki Edits: 22
That's really good to know, great info Nolan.
Radio Upgrade 65 Impala 65bluess Electrical 1 04-16-2010 08:23 PM
Cutting a hole for an in-dash stereo DanTwoLakes Hotrodding Basics 18 06-02-2008 06:45 PM
WANT TO TRADE? LHD 64' Impala dash for RHD 64' Impala Dash garagedoreen Interior 1 11-18-2007 07:55 AM
63 impala Am radio derwood3 Electrical 6 10-08-2004 06:50 PM
taking dash apart to install radio 78 camaro sevndoldscutlas Interior 3 02-25-2004 08:23 PM
