Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1966 nova alignment issue
Old 10-24-2012, 03:38 PM
sedan delivery's Avatar
sedan delivery sedan delivery is offline
alignment
the specs you posted look ok except the toe in..check around for someone thats done this for many years. i believe the toe in should be half that for each wheel. if you put 1/4inch per wheel you will surly wear out your tires. an 1/8 inch per wheel should be about right.
