1966 nova power disc brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2009, 05:35 PM
Someone please help. I just did a power disc brake conversion on my 66 nova. Most everything went ok,when I got to the bleeding process I have leaks at both banjo bolts. I used the copper washers properly and torked them to 45psi. When I found the leak I kept torking tighter, but they just keep leaking. I dont no what to do at this point.
Old 04-25-2009, 08:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Did you buy remanufactored calipers? if you did the bolt might be bottom out.had this problem before. check the bolt see if it is cracked. get new crush washers also. and make sure the caliper is not cracked. they make a aluminium washer also that might work. do you have washers on both sides of the bolt. hope this helps. Cole
Old 04-26-2009, 10:38 AM
66 nova brake conversion
All components are new,calipers look good,nothing looks to be cracked, I did use a crush washer on on each side of banjo bolt. Still leaking.
Disc Brake Conversion RJMUSTANG Suspension - Brakes - Steering 2 10-15-2007 08:08 PM
Heidt or SSBC Disc Brake Conversion Kits? twborbely Suspension - Brakes - Steering 5 06-27-2007 02:12 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
`33 Ford disc brake conversion Mike Humphrey Suspension - Brakes - Steering 0 02-17-2002 03:49 PM
Disc brake conversion for 1966 Chevy P.U. Herb Suspension - Brakes - Steering 2 02-10-2002 08:20 PM
