1966 Pontiac 389 Q-jet help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2010, 09:46 PM
I have a 1966 Pontiac Starchief two door hardtop, and it came with the 389 2 barrel engine with the 10.5 to 1 compression ratio. I am currently running that engine with an edelbrock performer intake and a quadrajet form a 76 suburban. I am wondering if anyone has any good specs on the Qjets to run on the 389 well, ( jet size, metering rods, secondary metering rods, etc.). Also if anyone is running a Pontiac 400 how are you running your quadrajets? I have tried a couple different jet and metering rod combinations, but am wondering what others have done and what has worked well for them. The engine still has the old points distributor and I am planning on putting in an HEI, so I want to install the HEI and then get my Q-jet dialed in and then put an electric choke on it. My engine is stock except for the edelbrock intake and headers. I am a newbie so I am just looking for the best way to setup my stock 389 and get the best performance I can out of it.
Old 05-13-2010, 05:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Let the plugs tell you if the carb needs jetting changes. The Suburban Q-jet will be close on the primary side, the secondary side could be changed to a richer rod, say a "BD" for a start.
The power piston spring should also be rich enough for the 389, considering it's in a heavy car.
The air door spring may need to be adjusted to fine tune the secondary opening. Go in 1/8 turn increments and write the changes down as you make them- you'll never remember after the first couple times!
Rebuilding Pontiac 389 gto67ron Engine 15 08-23-2010 06:23 AM
389 pontiac baadgoat65 Engine 3 06-09-2008 10:43 AM
need help pontiac 389 with 400 heads RedFox Engine 4 12-29-2007 09:41 PM
pontiac 389 or 400 Rufus_2 Engine 3 04-01-2006 03:39 AM
63 pontiac 389 1967bird Introduce Yourself 1 11-22-2004 06:53 PM
