1966 Thunderbird Master Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2010, 12:03 PM
I'm looking for a master cylinder to convert my single (suicide) to a duel Master cylinder in a 1966 Thunderbird. I've had quite a time trying to find something "Bolt-In". Seeing as how there are a ton of duel masters out there with the same bolt pattern there has got to be one that works. Some one HAS to have done this before without making a hooky jumbled mess of fitting and grinding/cutting. I've been directed to a '73 Mustang master, but it was a mess with all the fitting elbows and conversion fittings. Is this my only option? Is there a company that has more than just a generic style that might work . I'm no stranger to fabrication and hard work-my career demands it-I just think there is something better. Any help is greatly appreciated.
The Following User Says Thank You to Liveaxle For This Useful Post:
funkworx (02-21-2013)
Old 03-12-2013, 10:19 AM
has anyone solved the problem yet?
which parts were used, what difficulties are to be expected, a manual would be great.....
After a total failure of the brakes on my ford thunderbird 66 convertible I also want to convert to a dual master cylinder
I would be very grateful for help, Michaela
Old 03-12-2013, 11:38 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Need to know do you have manual or power brakes..makes a difference..later model Ford master cylinders should bolt up and then you will need to re-plumb the brake lines to the more modern configuration..
Sam
Old 03-12-2013, 01:45 PM
Hi Sam, thx for your quick response.
My 66 Tbird Convertible has power brakes. A problem is there is very little space under the shock tower braces and the additional round strut bar the 66 T-Bird convertible is equipped with.
So I look for someone who has already done this successfully and can send me pictures and "what to buy"
Buy all sorts of parts and try it isnt a option for me because shipping to europe is very expensive.
Michaela
Old 03-12-2013, 01:52 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
73 Ford master should do the trick
but you must know
Disc brake master and a drum brake master is different
power brake and manual brake is different
so if you now have power discs on the front---you need a power disc master.
master and booster problem/c5 conversion chevelle327C5 Suspension - Brakes - Steering 2 01-09-2010 10:13 AM
1966 ford thunderbird brash678 Introduce Yourself 1 08-28-2007 09:52 PM
disc brake conversion master cylinder Eric64 Suspension - Brakes - Steering 9 09-26-2006 04:19 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
1966 Chev PU upgrade to dual master cylinder for existing brakes Bannear Suspension - Brakes - Steering 7 10-23-2002 02:15 PM
