Are 1967 and 1968 Headlight Housing Mounting Bracket the same? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2011, 11:28 AM
oldtimercarnut's Avatar
Hi Guys
I am trying to find out if a standard 1967 camaro and a 1968 camaro have the same Headlight Housing Mounting Bracket. If so do they both mount to the fender or just the rad. support. Thanks for your help.
Old 04-12-2011, 12:36 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
They mount to the core support as I remember. I worked on these cars when they where daily drivers.
Old 04-12-2011, 01:37 PM
yes they do mount to the core support with two bolts but do they also mount to the fender? And if they do are the mounting holes in the same place for both cars. Thanks
Old 04-12-2011, 01:43 PM
swvalcon's Avatar
I would think they would there wasn't much change from 67 to 68. The big change came in 69. then again in 70
Old 04-12-2011, 01:49 PM
Thanks for the reply. I have a 1967 Camaro and I thought that the rad. support had never been changed but they are dated 1968. The car was make late in the year so maybe they just started using 68 parts. I was confussed because the holes for the fender look like they would not line up. But maybe they will. Thanks again
Old 04-12-2011, 02:41 PM
DanTwoLakes's Avatar
Wiki Edits: 22
'67, '68, and '69 are considered the first generation of the Camaro, and all three had the same body. The change in body style came in 1970 and lasted through 1981.
Old 04-12-2011, 02:48 PM
TucsonJay's Avatar
Actually the main body was similar, but the headlight area and front fenders were restyled for '69. I had an SS ragtop. Check out some pictures, and you can see the difference.
Old 04-12-2011, 02:54 PM
Thanks swvalcon
I was just checking to make sure there were no changes with the headlamps between the three years. There were some small changes like side fender lights, in front and back that the 1967 did not have. But I guess the inside of the fender where the headlights connect never change those three years.
Old 04-12-2011, 03:23 PM
Wiki Edits: 22
You are correct. CLICK HERE They claim all the sheet metal was different for 1969, but I sure don't see it.
Old 04-12-2011, 03:47 PM
TucsonJay's Avatar
As you can see on the first one, the headlights are right at the edge of the fender.
On the second one, the headlights look to be closer together, with a grill section outside the light bezels.
If you look at the body seam above the lights, it looks like the headlights were moved inward slightly.
Also Chevy added a body line off the top of all four wheel openings that fades toward the rear, including the door skins.
I'm not saying that the headlight buckets are different. I am just saying you should check it out to be sure.
Comparing GM part numbers for the different years might be a good starting point.
Like I said.... I had one. :-)
ID:	54403   Click image for larger version
Old 04-12-2011, 03:55 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
69 camaro has a flatter, wider body style then 67/68.
Cole
Old 04-12-2011, 06:08 PM
When you take the 1967-68-69 camaro and look at them all together it is like those two pictures in the news paper that always said, "Can you find the ten referents in the pictures" Shoe smaller, one button instead of two, ect. But with camaro's it is Wing Window, round parking lights, grill has more point , ect. What made me think they may be different on 1967 from 68 is if you look to buy them all seem to be sold as 67 or 68 not 67 through 69. That is what made me think there may be a referents
Alternator Bracket Mounting SBC Help sexypizzaman Engine 14 04-15-2009 01:56 PM
Bracket Mounting - Non-Acces. Heads ParatrooperAlex Engine 10 03-07-2009 09:32 AM
Mounting headlight relays jcarter Electrical 5 12-17-2007 07:14 PM
605 MOUNTING BRACKET/63 IMPALA OMAR Suspension - Brakes - Steering 1 10-09-2002 12:56 PM
605 MOUNTING BRACKET OMAR Hotrodders' Lounge 0 10-06-2002 06:16 AM
