1967 1972 f-100 ifs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2008, 08:34 PM
1967 1972 f-100 ifs
I have a 67 f100 that i need info about possible ifs. I have a 64 f100 s/s that has a volare -it has been a fun driver -but i was thinking something different-any body installed a aerostar front irs.it looks interesting-i purchased one from a junk yard-compact -all in one piece-rack-disc bracks. any ideas?
Old 01-17-2008, 11:25 PM
Wiki Edits: 27
newer ifs
I have seen them under 50's trucks owner said it was and essy swap. why are you getting rid of the mopar ifs???
Old 01-21-2008, 04:45 PM
ford i.f.s.
I have a 1964 step-side that I have installed a volare about 8 years back. I have 1967 short wheel base truck that I want to change to i.f.s. I want a daily driver-the aerostare i.f.s.-it has 302h.o.-ps.-air-pb. I tried 3in dropped spindles -still rode like a truck.
Old 01-21-2008, 05:07 PM
powerrodsmike's Avatar
Wiki Edits: 161
I had an 89 Aerostar van and looked at the way it was constructed. It was a bolt in, in the Aerostar, I don't see why you couldn't use it under the truck for a DD.. Check your frame height to see if the ride height will change. IIRC they have bushing kits and good swaybars and stuff like that for them.
I used to beat the crap out of mine, and it seemed to take all the abuse I could give it. I know the courier services and service companies used them alot around here. That is a statement in itself.
I would not use it if you are using your truck for heavy duty stuff, like towing and heavy weight work. I don't think it would stand up and the brakes are kind of small.
Later, mikey
BE different....ACT normal.
What Kind is this? BarryK Suspension - Brakes - Steering 3 09-03-2007 04:06 PM
mustang ifs need help choosing a set up legionlleh Suspension - Brakes - Steering 8 02-11-2007 07:16 PM
1967 f 100 jisbell Engine 4 01-13-2007 01:27 PM
1967 - 1972 chevy truck or blazer bucket seats oldschool Interior 4 10-23-2006 08:36 PM
TCP Vs. Fat Man IFS 1965-Mustang Suspension - Brakes - Steering 9 11-25-2003 05:01 PM
