Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1967 400 with 670 heads. Trying for 400 Hp street
Old 07-19-2012, 05:18 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Wiki Edits: 9
You will need to use the valve springs the individual manufacturers recommend for their cams for warranty issues. If you have the money, a retro hydraulic roller is a no brainer. Rocker ratio depends on the cam, how much lift, piston clearances, etc. When you start getting into the 400 hp range, rethink that stock 10-bolt. Depending on your cam choice and build, 2500 stall may not be a little short. JMO
