1967 c10 axle conversion questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2009, 11:32 AM
FRANKBULLITT's Avatar
Im lowering the truck and have gotten a kit from ccp with 5 lug front rotors and need to swap out the rear axle from 6 lug to 5 lug, and was wondering .What axle I can put in, that has 5 lug to match the front.I just want to use the drum brakes on the 5 lug axle.Trying to keep the cost down.
Old 06-29-2009, 12:31 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
http://www.earlyclassic.com/catalog....ry=New%20Items
The other option is to change the rear.
Rich
Old 06-29-2009, 12:51 PM
yeah I saw that already and was thinking 300 for the axles and 300 for the new brakes why not find a suitable used replacment other option was adapters for 200 was just wondering what I can use to replace it with only 5 lug
Old 06-29-2009, 01:14 PM
from another site.
http://forums.classictrucks.com/70/7...ion/index.html
Old 06-29-2009, 01:25 PM
I installed a set of axles and drums from a 75 c10 truck into my 70 c10 rear end.
Real simple.
Old 06-29-2009, 10:09 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Ditto that ^^
Old 06-30-2009, 06:41 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
67 c-10 axle conversion
I know this wont help you,because you have the big bolt pattern on your rotors,but I converted my 1969 c-10 to 5x4 3\4 bolt pattern by using axles from a 1965 Impala.If I remember correctly they slipped right in.I dont recall any machine work. I used adapters on the front so I could run corvette rallys all around.
Old 06-30-2009, 09:00 PM
fast68's Avatar
likes chevy trucks & boobies
if you find a BIG 10 or a common heavy suspension package '77-80 years c-10 pickup it will have the 2.75" wide rear brakes if you take the backing plates and axle shafts and brake parts from that and put them on the '64-69 axle housing it will convert these to 5 lug with no width modifications
if you have coils spring type rear then you will be stuck with a '71 72 axle only
the 70-up axle housings are all a new wider width but '70 shafts are all 6 lug still. after 70 the only 6 lug shafts were the 4x4 ones, exact same shafts as the 1970 ones.
if you have leaf type rear then you can take any 12 bolt axle from a 2wd and put it under, but in 73 the shock mounts changed
454 c10 got away with '75 parts because he has a 70 c10 axle in which is same width housing and axle shaft length as 71-up
so another words the longer 70-up shafts wont work in a narrower '69 down axle unless you swap backing pates and all from a 2.75" wide brake axle.
Old 06-30-2009, 11:21 PM
Earlier '70 rears tended to be the same width as earlier years, since it was a mid-year change.
700R4 trans conversion to 70' C10 2WD steve d Transmission - Rearend 5 01-31-2004 01:56 AM
1967 firebird - camaro conversion Johnny Bravo Body - Exterior 3 10-10-2003 12:30 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Ford Ranger V8 Conversion Transmission Questions nightrain_rod Transmission - Rearend 3 06-24-2003 05:56 PM
Gross to net HP conversion and more Pontiac questions Wmarden Engine 6 11-18-2002 03:28 PM
