Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1967 C10 Chevy Pickup
Old 04-04-2013, 03:34 PM
gearheadslife gearheadslife is offline
Banned
Originally Posted by Karcrazy View Post
Yes, had heard that the front end suspension would bolt right in. There are Camero parts that you can get but im sticking with truck parts. Especially if im going to go big block. I was going to switch the rear end anyway. The pickup was set up for work and has a low rear end in it so it will get a five bolt setup in the rear also. The pickup was my grandfathers who was a farmer and pulled a lot of things with it and the Chrysler was my grandmothers so marrying the two up is fitting.
Thanks for the link!
go to the junkyard 1973-87 c-10 front end with engine crossmember bolt in..
get it all crossmember and the whole works.. (a arms,spindles,etc..)
then just change your outer tie rods for the 73-87 ones and it bolts in..
the 73-87 came with two different thickness rotors 1" standard 1 1/4" heavy duty.. keep that in mind when ordering rotors and clappers..
also the 73-87 front sway bar is a bolt in.. you just need to get the frame brackets when you get the bar..
