1967 C10 Chevy Pickup - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-05-2013, 09:20 AM
RWENUTS's Avatar
Having the rad and fan won't hurt. You'll likely need a custom fan shroud after you get it in. If you're going headers or need mount ideas then heres a link.
Schumacher Creative Services
I've used their headers. Fit like a glove, starter access is excellent.
  #17 (permalink)
Old 04-05-2013, 02:16 PM
Or, do I dump the original fan assembly and put a regular pulley on the waterpump. Then go with a totally electric fan setup? Any experience with those? Or maybe then you are relying on the fan thermostat too much to keep things cool. Our Chevy Avalanche has a setup like that and it works really well, plus gives your a tad bit better gas mileage.
  #18 (permalink)
Old 04-05-2013, 02:18 PM
Definitely going with headers and I believe flowmasters. I will take a look at the link.
Thanks!
  #19 (permalink)
Old 04-05-2013, 02:44 PM
Banned
here you go.. cheap easy and fits stock shroud..
and from moparparts.com the fan is a woop'n 59.00
it's the famous jeep grand cheroke fan install for 67-72 trucks
you'll thank me later..
I got the fan it was 59+12 shipping and a fan controller from jegs or summit.. have to go look.. it was like 40-50 bucks..
another cheap electric fan build! - The 1947 - Present Chevrolet & GMC Truck Message Board Network
The switch, relay, and harness i used was a jegs kit, part number 555-10560 $45.99
fans P/N: CBG4F250
https://www.moparpart.com/oem-jeep-parts.html
  #20 (permalink)
Old 04-05-2013, 08:55 PM
techinspector1's Avatar
Wiki Edits: 326
I like to use the mechanical system from the vehicle that's supplying the motor. Get the motor/trans in place, then adapt all the cooling system from the Mopar. You may have to do some cutting on the core support to adapt the radiator, maybe not. Look at the Mopar before you pull the motor and measure and record the distance from the fan to the core so you can position the radiator exactly the same distance from the fan and you will have everything in place, including the shroud. The motor will cool exactly like it did when it was in the Mopar sheetmetal. Chrysler Corp paid its engineers top dollar to design and build a cooling system for that 383 that would do the job under many varying conditions. Take advantage of the free engineering. That's my best advice.
  #21 (permalink)
Old 04-06-2013, 09:06 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Mopar into a chevy eh well I suppose,,, there is an old saying it goes "if the shoe fits wear it"
FWIW when I did my first V8 swap from the original straight 6 250 in my C10 I used the single core rad that was in the truck up until I went to the current 383 (stroker not mopar). I had a fairly hot 350 in there for a while and never had an overheating issue without a shroud and no aux fan either. The orignal single core rads have a huge surface area at least this was the case n the 72's not sure of the 67's capacity or what type rad you have now. Dont forget the trans cooler.
The flexalite black magic fan is what I run now with a some back yard brackets, using a flexalite variable speed soft start controller which is great and a tripple core rad from a 69, no fan on the motor, a manual override can be connected to these controllers to bring the fan on through a toggle switch, cool as a cucumber
ID:	72950   Click image for larger version
  #22 (permalink)
Old 04-07-2013, 06:46 AM
Use a ford mid 90's electric fan from a t-bird or taurus.
if your are don't a disk swap then don't forget to also get the 5 lug axles. They also bolt right in into the 67 housing.
You will also need a set 5 lug wheels.
  #23 (permalink)
Old 04-08-2013, 10:48 AM
Got it. Keep the great tips comin! I thought some more over the weekend about this and originally I was going to put a little bit bigger cam in the Mopar but then again, not really looking to go totally nuts. So, in everybody's opinion, would there be a need for a super coil electronic ignition or just go with a straight conversion over from points to electronic? That may have sounded really contradictory but I dont have alot of experience with converting over from points. I remember a really simple kit that you could buy back in the 80's that you installed in place of the point setup inside the distributor.
Also, I plan on getting an aluminum intake for it also. With a stock cam, what kind of aluminum 4 barrel intake and what size carburator would you guys suggest?
  #24 (permalink)
Old 04-08-2013, 01:45 PM
Wiki Edits: 326
Here's what you're thinking about.....
Ignitor
I wouldn't change the camshaft until I knew for sure what the actual static compression ratio of the motor is. I know fellows have changed cams in motors for decades without knowing anything about the inside of their motor, but that doesn't mean they did it right!!!!!
Static compression ratio should be matched to the intake closing point of the camshaft in order to generate the proper cylinder pressure for the fuel you're using. It's called Dynamic Compression Ratio and if you're going to maximize your cam change, you need to figure it all out first.
As far as an intake manifold, with a stock cam I'd retain the stock intake manifold, unless you just want to lighten your wallet and take a few pounds off the front of the truck. AGAIN, the Chrysler engineers figured the exact size and length of the intake runners on the stock piece to provide the best overall performance. Until you tear into the motor and change everything, I would leave the stock piece on there. A 600/650 carb will be all you need.
  #25 (permalink)
Old 04-08-2013, 02:24 PM
Yes, that is exactly what I remember and now that I see the name I remember that also. What you said makes sense. The 1965 383 Mopar with a 4 barrel carb is rated at 330 hp (at least from what I found on the net) thats plenty actually for such a light truck really. I may gain a few horses with headers, dont need to make a wheelie machine or have something that I cant keep rear tires on,,,,,,yet.
Thanks!
78' Chevy C10 Pickup transmission problems arnellwest Transmission - Rearend 1 08-08-2011 03:43 PM
1969 chevy c10 pickup Ray Thompson Introduce Yourself 1 05-30-2006 06:14 PM
Wheels for a 1967-72 Chevy Pickup 68ChevyMan Introduce Yourself 1 07-26-2004 10:09 PM
70 Chevy Pickup C10 Bad BlkS10 Introduce Yourself 5 06-30-2004 07:29 PM
1967 Chevy Pickup tonyt Electrical 9 08-19-2003 09:11 AM
