1967 camaro ignition removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2007, 08:32 PM
I'm restoring a 1967 camaro....how do I remove the ignition?
Old 01-05-2007, 08:49 PM
poncho62's Avatar
Wiki Edits: 5
Put the key in the ignition and turn it to accessory....There is a small hole in the face of the tumbler. Stick a paper clip, small ddrill bit etc in there and push in. At the same time turn the key more to the left. That will remove the tumbler. Then undo the nut to take the switch out....
Old 01-05-2007, 10:19 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Good save Poncho.. Moving to Gen rod tech..
Sam
Old 01-06-2007, 08:15 AM
Thanks for the information, Poncho.....worked exactly like you said...Thanks again.
84 CAMARO DRIP Rail Removal x711 Body - Exterior 2 12-16-2005 12:36 PM
1969 Camaro HEI ignition location Question Izzy17ri Engine 1 12-08-2005 04:38 PM
1967 firebird - camaro conversion Johnny Bravo Body - Exterior 3 10-10-2003 12:30 PM
1967 Chevy Camaro Hellp ToYoungToCare Body - Exterior 13 08-18-2003 05:38 PM
1967 Camaro d_67_camaro Interior 2 02-01-2003 02:37 PM
